Hi, recently I switched from windows to mac but there is no Softether VPN client avaliable for mac OS sierra.
I installed the latest tar.gz avaliable for mac but I dont know how to configure the vpn connection. Can someone help me?
Or instead send me the link for Softether GUI v1.0.3? I have SoftetherGUI 1.0 but i cannot use special characters in it.
Ty
Help Configuring VPN on MacOS
littlejonny17
Re: Help Configuring VPN on MacOS
Can anyone link the 1.0.3 version of the softetherGUI?
Could you try to run the SoftEther VPN Client Manager on Wine?
ePrime
Hello. using a VPN is easy on the Mac. There's a built-in VPN and Proxy you can use in the system preferences.
System Preferences > Network > Click on the + > Add a VPN (I2TP over IPSec) and add an IP on VPNGate as the server address.
(Make sure pick an address that has L2TP as an option)
Account name "vpn"
Click on Authentication settings
Password and shared secret are "vpn"
Click ok
Click on "Advanced"
and enable "Send all traffic over VPN connection"
Click OK
Click on "Apply"
and start Connection.
If you wish to use an external program; There's an OpenVPN called 'Tunnelblick'
I explain it more in this tutorial on Imgur (However I used VPNBook instead of VPNGate in this example)
https://imgur.com/a/CENzA
Hope it helps.
Account name "vpn"
Click ok
Click on "Advanced"
Click OK
Click on "Apply"
Hope it helps.
