question on the lan to lan bridge connection
colapig
For the Lan to Lan bridge connection. I would like to know if each branches can access headquarter each other? even they using different IP segments?
Re: question on the lan to lan bridge connection
Please check this manual.
http://www.softether.org/4-docs/1-manua ... P_Routing)
