I edit 'vpn_server.conf' setting:
declare DDnsClient
bool Disable true
However, when I restart the vpnserver it sets back to false. The whole file is re-written.
How do I fix?
DDnsClient Disable
Re: DDnsClient Disable
Did you edit a configuration file while running the server?
I believe that was the issue. I've managed now to include the disabled stanza in my config:
declare DDnsClient
bool Disabled true
Thank you
declare DDnsClient
bool Disabled true
Thank you
