Can't Connect to Servers
Need help guys!!! After updating SoftEther VPN to the latest build,i noticed that i can't connect to the many of the servers listed like i normally do.This happened whenever i tried to connect via TCP protocol.Strangely this did not happened when i tried to connect via UDP protocol though. Before when i was using the previous build (SoftEther VPN Client Ver 4.10, Build 9505, beta),no problem in connecting via TCP protocol.Whenever i tried to connect via TCP protocol lately,an error pops up (Error code : 2). Please can anyone help me with this problem. Thanks in advance guys.Cheers!
Re: Can't Connect to Servers
119 views!!! no solutions yet..lol
The update did say it might break some compatibility due to OpenSSL upgrade. Did you try downgrading? If that works, use the old one and make sure to report the issue.
I use 9529 and works fine, will test the new versions weekend, but will not upgrade production servers just yet. That warning is for a reason.
