hello every one
I installed SoftEther VPN on my vps and is working good i connected my SoftEther VPN using LT2P that's good but i want to connect my vpn using openvpn and for that i think i need to creat .opvn file . i m right ??
that problem is that i don't how to connect my SoftEther VPN using openvpn software
please help
thank you
how to connet my softether vpn using openvpn
Re: how to connet my softether vpn using openvpn
On the server side you need to generate the .ovpn file, upload it to you're device and use that file in openvpn to connect. Sometimes (depending on the server installation), it is wise to check the server address in the ovpn file. Do not forget to open the openvpn port in you're NAT router (if present).
thank you mesa57
1st i don't how generate the .ovpn file 2nd Do not forget to open the openvpn port in you're NAT router (if present). i don't understand what u trying to say
my dear measa57 i m not very good at programing . but pls enplane me more detail and tell a easy way to create .ovpn file
thank you
thank you
thank you mesa57 it really help full for me
can u pls tell me how create .ovpn fill
thank you
thank you
On the screen link :
button : generate sample configuration file for openvpn clients
Did you ever look at that link ? It is crystal clear what to do ...
thank you mesa57
that time i don't see but i now i see thank you
u r great help
thank you
u r great help
thank you
thank you mesa57
i love you its work like magic
thank you u really help me
