i have solved this issue with SSTP by adding the softehter created certificate directly to Windows
now i want to be able to use the OpenVPN configs for my phone but am not able to due to certificate error on both Windows and Android OS.
the already added certificate does not work nor help !
Can't get OpenVPN to work- certificate error
Re: Can't get OpenVPN to work- certificate error
Did you change your cert in SoftEther? If yes, you have to re-generate your openvpn "example" config.
did that. Does not work...
Looks for a root certificate ? do i have to buy one ?
Does OpenVPN client load the "Example" file directly?
"Example" file contains certificate.
