Please Help
VPN Client>niccreat
NicCreate command - Create New Virtual Network Adapter
Virtual Network Adapter Name: vpn
Error occurred. (Error code: 31)
Installation of the Virtual Network Adapter device driver failed.
VPN Client>
root@freebsd-router:~ # kldload if_tun
kldload: can't load if_tun: module already loaded or in kernel
root@freebsd-router:~ # kldstat
Id Refs Address Size Name
1 3 0xc0400000 13ed800 kernel
2 1 0xc685a000 5000 if_tap.ko
SoftEther VPN client for FreeBSD
Re: SoftEther VPN client for FreeBSD
SoftEther VPN Client doesn't support FreeBSD.
https://www.softether.org/3-spec
Please use OpenVPN or L2TP/IPSec.
I need connect to SoftEtherVPN server. I have IP, login and pass.
