Error occurred. (Error code: 29)
LouisIsMyDog
Post by LouisIsMyDog » Mon Nov 16, 2015 2:31 am
Hi Softether Community,
My situation:
On Linux Mint I am using Softether Client. On vpncmd with the command 'AccountConnect' I get the error 'Error occurred. (Error code: 29)
Object not found.'
I set 'AccountCreate' with 'AccountPasswordSet' with the correct infomation. I do not know what the problem is. Can someone shine some light on the situation. Thanks in advance.
raafat
Re: Error occurred. (Error code: 29)
Post by raafat » Mon Nov 16, 2015 2:41 am
The error says that you provided a name of account that not found(object not found), so make sure you'r writing the correct name and double check the spelling of it
usually you have to do something like this :
Creating the NIC : NICREATE mynic
Creating an account that will be using the just-created NIC (we named it mynic) : accountcreate myaccount
(above you have to go through a few questions, so double check that you are aware of your answers)
Setting the password of the user name of the just-created account : accountpasswordset myaccount
and finally
Connecting the just-created account to the server
accountconnect myaccount
Good luck
LouisIsMyDog
Post by LouisIsMyDog » Mon Nov 16, 2015 3:50 am
I did not realize that I had to create a NIC.
Sorry newb here.
So here is my input and output:
'VPN Client> NicCreate
NicCreate command - Create New Virtual Network Adapter
Virtual Network Adapter Name: vpn_adapter
Error occurred. (Error code: 31)
Installation of the Virtual Network Adapter device driver failed.'
I do not know what is wrong.
raafat
Post by raafat » Mon Nov 16, 2015 9:54 pm
You have to run the vpnclient with sudo
sudo ./vpnclient start
Good luck
rasterjannik
Post by rasterjannik » Thu Aug 15, 2019 1:44 pm
Hi you all,
I have the same problem as LouisIsMyDog.
After
niccreate vpn_c2
I have got
Error occurred. (Error code 31)
Being not root can not be the reason for this, because this is an embedded machine and there is no other user than root.
with vpncmd I sent the command 'check' to the client an it answered that all is ok.
The whole works on an ARM9 and vpnserver is doing fine.
Running vpnserver together with vpnclient also can't be the problem, because on one other machine this constellation does well.
Help would be fine.
Kind regards
rasterjannik
genesys
Post by genesys » Mon May 04, 2020 2:54 pm
I'm also getting Error code:31 despite running the client with sudo
Trying this on Mac os x
