IPV6 on mobile devices
quattrolinux
Re: IPV6 on mobile devices
Post by quattrolinux » Wed Mar 02, 2016 5:54 pm
thisjun wrote:
> SoftEther doesn't support such function.
Any plans to enhance SoftEther OpenVPN compatibility to enable OpenVPN like IPv6 support?
For this exact reason I must use real OpenVPN to serve mobile devices.
Post by thisjun » Wed Mar 30, 2016 7:34 am
PPP implementation of SoftEther VPN doesn't support IPv6.
vitaliksys
Post by vitaliksys » Fri Jul 01, 2016 6:44 am
can you please post your dnsmasq config to get ipv6 ?
quattrolinux
Post by quattrolinux » Fri Jul 01, 2016 3:07 pm
Right now I have the following configuration:
site 1 with IPv4 and IPv6 provided by E1200 router. One of the systems there runs vpnserver bridged to a physical network interface.
site 2 with IPv4 only, each system in a need for IPv6 runs vpnserver bridged to a tun and hub chained to site 1 hub. tun device configured to ignore IPv4 and automatic IPv6, resulting in IPv4 address/route from local DHCP and IPv6 address/route from remote E1200.
raafat
Post by raafat » Tue Jul 05, 2016 8:15 pm
Hi there, kindly, let's know what going with you and if you solved your problem, it's a good idea to let's know that (:
Good luck (:
