10.6 Build a LAN-to-LAN VPN (Using L3 IP Routing) with tap
quattrolinux
Post by quattrolinux » Sat Jan 16, 2016 5:16 pm
In my lab the scenario described in https://www.softether.org/4-docs/1-manu ... Routing%29 is working perfectly. However in the virtual environment the MAC address spoofing, required by Ethernet bridging, is not working. I am currently investigating if the same LAN to LAN level 3 IP routing functionality can be accomplished without Ethernet bridges.
Has anyone ever done it?
Re: 10.6 Build a LAN-to-LAN VPN (Using L3 IP Routing) with t
Post by thisjun » Thu Jan 28, 2016 7:50 am
What's the problem?
