Broadcast
Jarleavloyp
Broadcast
Post by Jarleavloyp » Fri Jan 22, 2016 12:59 pm
Hi
After connecting the SoftEther VPN Client the routing table is update.
We have some local broadcast communication on the client that stops working after the SoftEther client is connected to the server.
It’s there any way that we can connect without that the local broadcast communication is update?
mvh
Jarle.
Jarleavloyp
Re: Broadcast
Post by Jarleavloyp » Sat Jan 23, 2016 7:39 pm
Seems that the broadcast is redirected to the external network?
Jarleavloyp
Re: Broadcast
Post by Jarleavloyp » Wed Jan 27, 2016 7:54 pm
Not anybody that can help with this?
eastavin
Re: Broadcast
Post by eastavin » Wed Jan 27, 2016 9:56 pm
Are you referring to the clients keep alive transmission? If not needed you can disable it. https://www.softether.org/4-docs/1-manu ... _Functions
Jarleavloyp
Re: Broadcast
Post by Jarleavloyp » Wed Jan 27, 2016 10:03 pm
> disable it.
I'm refering to the route 224.0.0.0 240.0.0.0 On-link 192.168.30.54
The 192.168.30.0 is the external network. Seems like the broadcast is also route, this does not happen with our IPSEC VPN connection.
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.23.1 192.168.23.197 20
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.23.0 255.255.255.0 On-link 192.168.23.197 276
192.168.23.197 255.255.255.255 On-link 192.168.23.197 276
192.168.23.255 255.255.255.255 On-link 192.168.23.197 276
192.168.30.0 255.255.255.0 On-link 192.168.30.54 257
192.168.30.54 255.255.255.255 On-link 192.168.30.54 257
192.168.30.255 255.255.255.255 On-link 192.168.30.54 257
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.30.54 257
224.0.0.0 240.0.0.0 On-link 192.168.23.197 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.30.54 257
255.255.255.255 255.255.255.255 On-link 192.168.23.197 276
Persistent Routes:
None
eastavin
Re: Broadcast
Post by eastavin » Thu Jan 28, 2016 3:11 am
I recall seeing something about this in the documentation. Just can't find it. Here are some ideas you will have to review for relevancy.
See 11.1.6 and 8 and 30
https://www.softether.org/4-docs/1-manu ... leshooting
See 3.4.8
Background 1.4.1
https://www.softether.org/4-docs/1-manu ... ion_Method
That all I got. Maybe another reader can advise?
Re: Broadcast
Post by cedar » Mon Feb 15, 2016 7:39 am
Did you try to raise interface metric value than physical NIC?
Jarleavloyp
Re: Broadcast
Post by Jarleavloyp » Tue Nov 22, 2016 8:17 am
Hi, did not try that will check this out.
Thanks.
