Some Windows computers do not always respect the metric of the network cards, thus also setting the metrics for virtual network card of softether VPN Client to an higher value, the computer uses it as a default gateway to the network of the VPN connection. There is a mechanism that allows you to delete default gateway supplied by DHCP (which is common and instead serves to other network stations) ? It would be helpful if this setting was configured per user, which for example allows OpenVPN.
Best Regards
