I've installed SoftEther VPN Server on my home computer, since I need to be able to connect to the Internet using my home IP from anywhere in the world.
I've followed this guide: http://ram.kossboss.com/softether-the-b ... t-forward/
I am able to connect from the client to the server, but when I go to ipleak.net - it's the clients IP that is shown as public IP...
I need help to set this up correctly so it's the IP of my home computer where the server is installed, that is shown to the world no matter where in the world I connect through the Softether VPN
Please only respond if you have experience with SoftEther and you are able to fix this over Teamviewer.
Freelancer needed
cst_zf
Re: Freelancer needed
> world.
I just guess, you should use the gateway of your home network in your client pc, then all is ok.
> world.
