Dear Friends!
I don't know how to install Softether VPN server on cmd prompt without GUI Management.
Isn't there any way to install server on cmd prompt like OpenVPN?
I want you to introduce the way how to do it.
Regards!
I need a help within installing Softether Vpn Server
W0nd3r
fenice
Re: I need a help within installing Softether Vpn Server
It tells you how to install SoftETher VPN in the product documentation, if you haven't read them then take a look at these pages:
http://www.softether.org/4-docs/1-manual
http://www.softether.org/5-download
http://www.softether.org/4-docs/2-howto
tharaka40
Hello friend if you provide me your server access ill installed it for you
contact via Skype : tharaka40
W0nd3r
Thank you for your help.
But I cannot find silent installation of vpn server in manuals. (e.g. softether-vpn_server.exe /install:silent)
How can I do it?
Regards!
How can I do it?
Regards!
tharaka40
> How can I do it?
> Regards!
Hello friend
IF YOUR SERVER IS CENTOS BASE THERE IS NO INSTALLATION EXE FILE ALL ARE CONFIG BY CLI . IF YOU WANNA RUN VPN SERVER MOST SUITABLE BASE IS CENTOS SERVER
BEST REGARDS
> How can I do it?
> Regards!
Hello friend
BEST REGARDS
Please run SoftetEther VPN server(not installer) with /install option.
