Hi everyone,
In recent days i have experienced a very strange problem using the VPN. I connect to my server and try to acess some of the blocked sites (by china) but they remain blocked, then i connected with a differet VPN (program) and everything works fina ( also it works if i dont use the Client). But i really want to solve this problem.
some info: I am using at the moment a Broadband connection ( pppoe ) and im not behind a router. I did a simple tracert to youtube or google and for an IP i get some ancient egyptian symbols, i fiddled with the DNS a lot which means i flushed it and reset it and changed some of the IP and reset them back to the original.
Thanks in advance!
ps: if i manage to fix it somehow i will make sure to make a post.
Websites remain blocked
kaundere
Re: Websites remain blocked
Well somehow it got fixed, i have no idea what has happened, I did not do anything to fix it, it just started working...
kaundere
Cause of this was DNS poisoning.
