Hi all,
is there a way to assign a static IP address to the VPN client depending from user?
Ex: User1 : 192.168.0.250 - User2 : 192.168.0.251 , User3 : 192.168.0.252, etc.
If you try to assign a static IP on the VPN adapter of the client, when I try to connect to VPN I get this error : "the specified address is already in use" ( with any address).
Can you help me?
Thanks.
Semola
VPN Client Static IP
Re: VPN Client Static IP
What OS did you use?
semola
In all machines (server and client) I have windows 10 64bit on server, other version on client (I don't remember the version of windows for the clients.
I have tryed to assign a static IP address to a client (192.168.0.248, configuring the TCPIPv4 protocol on the virtual network card) when the DHCP server assign only address between 192.168.0.100 and 192.168.0.200
When I try to connect with my server VPN, i get an error (the address is already in use).
Thanks
Semola
Thanks
Semola
Please confirm whether the IP address absent by IP address Table List in the virtual hub.
semola
I don't know if I understood. If you refer to "Manage Access List" section, In this section I don't have any data.
Thanks
Thanks
Please check "Manage Sessions" in management of virtual hub.
