OpenVPN SSL Failed
JellyVPN
OpenVPN SSL Failed
Post by JellyVPN » Sat Jul 02, 2016 2:33 pm
Hi and Thanks for helping me , everything in OpenVPN config correct and this is work until today without any problems , but today Give me https://1drv.ms/i/s!At8n1LALvdw3iHKhhs2McceseBrv
and Can't Connect , i can't find Solution ,
there is my config:
http://m.jvpn.us/Connection/OpenVPN/Con ... droid.ovpn
Please anyone help me , i can't understand what's happened today
also My Server Have the Signed SSL from Positive SSL (Comodo SSL)
https://www.sslshopper.com/ssl-checker. ... =m.jvpn.us
raafat
Re: OpenVPN SSL Failed
Post by raafat » Tue Jul 05, 2016 7:15 pm
Go to options on your smart phone and click on the Show log file option, post the result here and make sure to delete sensitive data from that log file, also, i suggest to try to skip the configuration with signed-SSL certificate and re-configure the SE server to accept the connection from OpenVPN client without that signed-SSL certificate, try a certificate that is locally generated, so that we know where is the problem, is it with the settings or with the certificate that you are provided from your SSL provider.
Good luck (:
