Maximum number of IPs to set in client vpn adapter
josesmith12389
Post by josesmith12389 » Tue Feb 06, 2018 10:24 pm
I am using SoftEther in AWS and I need to set multiple ips (more than 4) on the client VPN network adapter. When I do this I am not able ping more then 4 ips. In other words is it possible to have >4 ip addresses on a single client VPN adapter?
Thanks.
Re: Maximum number of IPs to set in client vpn adapter
Post by thisjun » Thu Feb 15, 2018 6:41 am
SoftEther VPN client doesn't handle the IP layer.
