Hi! First of all, great piece of software! LOVE it!
I have a hosted Dedicated Server running Windows Server 2016 and different SQL Databases on a single MS SQL 2017 instance.
Because there are many VPN clients that needs to connect to different databases on this system, I need many different hubs with separated VirtualNAT inside of them.
Now for testing purposes I've created a VirtualNat with DHCP - Standard 192.168.30.1.
If I try to build up a SQL Connection to 192.168.30.1 it doesn't work (well, even MSTSC, etc. doesn't work).
I've searched but didn't find a solution until now. Somebody out there who can give me an advice?
Thanks in advance,
Patric
How to connect to the VirtualNAT Computer?
Re: How to connect to the VirtualNAT Computer?
Virtual host of SecureNAT is a virtual host and not the host of VPN server.
Could you share your network configuration?
