server configuration file
hfw
Post by hfw » Mon Apr 09, 2018 10:17 am
I'm testing Softether VPN on my linux test machine (CentOS 6).
It apperas that when launching vpnserver for the first time, a default configuration files and a backup directory are being created with default values. One of the values is Listener on port 443 being enabled. I would like this listener to be disabled by default for it interferes with another daemon listening on this port.
How can I generate a custom configuration file before I start the vpnserver or adjust the default settings _before_ starting the vpn server please?
Thank you.
kdmiller45
Contact:
Re: server configuration file
Post by kdmiller45 » Sat Apr 14, 2018 5:39 pm
I have not looked at this config file, but most scripts by putting a "#" sign in front will disable that line and of course you could nano "filename" and change the value of the port you want to listen to
Keith The Geek
Post by thisjun » Wed May 16, 2018 7:52 am
Please create server configuration which is disabling port 443 on another VPN server and place it at same directory of new VPN server executable before launching the SoftEther VPN Server.
