Hi all!
I have to build 1 cluster vpn servers using SoftEther, but after have 1 controller, 1 members and connected successfully, the button config for IPSEC is disabled.
So how I can connect from Android device after enable cluster mode
Thanks so much!
VPN Cluster mode
raafat
Re: VPN Cluster mode
As far as I remember IPSec is one of the protocols which don't work In a cluster mode. OpenVPN doesn't, too. Double check for SE Docs for further information.
trongtb88
Thanks!
So how I can connect from Android to VPS cluster server without IPSEC and L2TP protocol?
How about DNS round robin?
okman1703
trongtb88 wrote:
> Hi all!
> IPSEC is disabled.
> Thanks so much!
Hi trongtb88,
Do u use statichub or dynamic hub?
> Hi all!
> IPSEC is disabled.
> Thanks so much!
Hi trongtb88,
