How create VPN connection inside LAN?
lebron2387
I Have several computers, connected in one switch. How setup server and clients to have encrypted data transfer between clients and server inside this local network? Thanks!
raafat
Re: How create VPN connection inside LAN?
Hello there! You could use a virtual hub to group all your clients and servers in one place(technically a virtual hub). Also you have to block all communication between clients and servers and ALLOW only communication between clients and the server that hosts "SoftEther Server". Refer to SE docs for further technical details.
Let me know if you need further help regarding your issue..
lebron2387
Solve the issue by creating LocalBridge in SoftEther VPN Server linking with main Ethernet adapter. Thanks!!!
