problems with "push routes"
ramadan
Post by ramadan » Sun Jun 10, 2018 5:45 pm
Good day. There is a server sofetherVpn on Debian that is fully configured and operational. The problem is that when I add more than 30 entries in my Hub (SecureNat->SecureNat configutation->edit the static routing table to push), it stops "pushing". That is, he pushes 30 pieces, but if I add plus one (31th), then the records does not "push" to touting table. Although it is indicated that a maximum of 64. There are suggestions in what can be the problem?
Re: problems with "push routes"
Post by cedar » Mon Jun 11, 2018 9:46 am
It seems that some DHCP clients can't handle DHCP response message over 300 bytes.
ramadan
Post by ramadan » Mon Jun 11, 2018 11:29 am
I am using standart win 10 wpn client to connect to my softether server. How can i solve it?
