I have nat vps, I followed tutorial from digitalocean, after installing vpnserver, I don't know with port should I use for VPN server manager, they gave me a range of ips and a single IP for ssh. what can I do about that?
VPN Server Behind NAT
cmd wh0ami
Re: VPN Server Behind NAT
it should be the default which is 443
bardulf
doesn't work with port 443.
Could you try to connect to the IP for ssh with the port 443?
