How do I find my Host Name?
strongsargonism
What is my host name and how do I find it? Really confused, please help.
Re: How do I find my Host Name?
The term 'host name' may have different meaning depending on the situation.
Please explain the detailed situation.
sammartin8935
To find your Host Name and Physical Address using the Windows Command Prompt:
Open the Command Prompt window by clicking on Start > (All) Programs > Accessories > Command Prompt.
Note: If you do not have access to the Command Prompt, please contact your IT department or someone with administrative rights to your machine to help you locate the information.
Type
ipconfig /all
and press the Enter key.
Your Host Name will appear at the top, under the section Windows IP Configuration:
Type
ipconfig /all
