cross compile ERROR: hamcorebuilder: not found
robert.berger
Post by robert.berger » Fri Aug 31, 2018 2:52 pm
I'm trying to compile the latest and greatest SoftEtherVPN[1] for some ARM 32 with Yocto.
It looks like it can not compile/run the hamcorebuilder. I guess the hamcorebuilder should be built for the host machine and not the ARM.
Is this correct?
softethervpn-native (which means compiled for the host/x86-64) seems to work.
Do I need hamcorebuilder compiled for x86 to cross-compile for ARM?
There is a similar post here[2]
[1] https://github.com/SoftEtherVPN/SoftEtherVPN
[2] http://forum.vpngate.net/viewtopic.php?f=7&t=61031&p=80370&hilit=hamcorebuilder%3A+not+found#p80370
Re: cross compile ERROR: hamcorebuilder: not found
Post by thisjun » Thu Sep 13, 2018 7:08 am
Yes, you are right.
robert.berger
Post by robert.berger » Fri Sep 14, 2018 12:57 pm
OK. Thanks!
If your new cmake approach[1] ready for cross compilation?
robert.berger
Post by robert.berger » Wed Jul 17, 2019 6:51 pm
I just gave it a shot and tried to make softether cross compile with the yocto project.
The recipe is here[1].
Please give it a try and let me know how it goes - it compiles today's version.
[1] https://gitlab.com/meta-layers/meta-res ... /softether
