Debian Stretch
Azunai
Debian Stretch
Post by Azunai » Thu Sep 13, 2018 12:56 pm
I have a clean installation of debian stretch and set up the latest binary supplied for Linux
 SoftEther VPN Server Version 4.28 Build 9669   (English)
2018-09-13 11:03:24.527 Compiled 2018/09/11 12:23:27 by yagi at pc33
this is the log if a client connects:
2018-09-13 12:32:31.310 On the TCP Listener (Port 4433), a Client (IP address 1.2.3.4, Host name "some.hostename", Port number 21268) has connected.
2018-09-13 12:32:31.310 For the client (IP address: 1.2.3.4, host name: "some.hostename", port number: 21268), connection "CID-10" has been created.
2018-09-13 12:32:31.361 SSL communication for connection "CID-10" has been started. The encryption algorithm name is "AES128-SHA".
2018-09-13 12:32:31.422 Connection "CID-10" has been terminated.
There is no error message to find anywhere.
Server config:
# Software Configuration File
# You may edit this file when the VPN Server / Client / Bridge program is not running.
declare root
	uint ConfigRevision 73
	string Region FR
	declare DDnsClient
		bool Disabled false
		byte Key akey=
		string LocalHostname myhostname
		string ProxyHostName $
		uint ProxyPort 0
		uint ProxyType 0
		string ProxyUsername $
	declare IPsec
		bool EtherIP_IPsec false
		string IPsec_Secret vpn
		string L2TP_DefaultHub VPN-recode
		bool L2TP_IPsec false
		bool L2TP_Raw true
	declare ListenerList
		declare Listener0
			bool DisableDos false
			bool Enabled true
			uint Port 992
		declare Listener1
			bool Enabled true
			uint Port 1194
		declare Listener2
			bool Enabled true
			uint Port 4433
		declare Listener3
			bool Enabled true
			uint Port 5555
	declare LocalBridgeList
		bool DoNotDisableOffloading false
	declare ServerConfiguration
		bool AcceptOnlyTls true
		uint AutoSaveConfigSpan 300
		string CipherName AES128-SHA
		uint CurrentBuild 9669
		bool DisableDosProction false
		bool DisableOpenVPNServer false
		bool DisableSSTPServer false
		bool DontBackupConfig false
		bool EnableVpnAzure false
		bool EnableVpnOverDns false
		bool EnableVpnOverIcmp false
		byte HashedPassword hashedpass=
		uint KeepConnectInterval 50
		uint KeepConnectPort 80
		uint KeepConnectProtocol 1
		uint MaxConcurrentDnsClientThreads 512
		uint MaxConnectionsPerIP 256
		bool NoLinuxArpFilter false
		bool NoSendSignature false
		string OpenVPNDefaultClientOption dev-type$20tun,link-mtu$201500,tun-mtu$201500,cipher$20AES-128-CBC,auth$20SHA1,keysize$20128,key-method$202,tls-client
		bool SaveDebugLog false
		byte ServerCert somecert
		byte ServerKey  somecert
		uint ServerLogSwitchType 4
		uint ServerType 0
		bool StrictSyslogDatetimeFormat false
		bool Tls_Disable1_0 false
		bool Tls_Disable1_1 false
		bool Tls_Disable1_2 false
		bool UseKeepConnect true
		bool UseWebTimePage false
		bool UseWebUI false
		declare GlobalParams
			uint FIFO_BUDGET 10240000
			uint MAX_BUFFERING_PACKET_SIZE 2560000
			uint MAX_HUB_LINKS 1024
			uint MAX_IP_TABLES 65536
			uint MAX_MAC_TABLES 65536
			uint MAX_SEND_SOCKET_QUEUE_SIZE 2560000
			uint MAX_STORED_QUEUE_NUM 1024
			uint MEM_FIFO_REALLOC_MEM_SIZE 655360
			uint MIN_SEND_SOCKET_QUEUE_SIZE 320000
			uint QUEUE_BUDGET 2048
			uint SELECT_TIME 256
			uint SELECT_TIME_FOR_NAT 30
			uint STORM_CHECK_SPAN 500
		declare ServerTraffic
			declare RecvTraffic
				uint64 BroadcastBytes 333445
				uint64 BroadcastCount 1881
				uint64 UnicastBytes 157192
				uint64 UnicastCount 1780
			declare SendTraffic
				uint64 BroadcastBytes 44650
				uint64 BroadcastCount 253
				uint64 UnicastBytes 57514
				uint64 UnicastCount 855
		declare SyslogSettings
			string HostName $
			uint Port 514
			uint SaveType 0
	declare VirtualHUB
		declare VPN-recode
			uint64 CreatedTime 1536804661956
			uint64 LastCommTime 1536810463941
			uint64 LastLoginTime 1536809549972
			uint NumLogin 4
			bool Online true
			string RadiusRealm $
			uint RadiusRetryInterval 0
			uint RadiusServerPort 1812
			string RadiusSuffixFilter $
			byte SecurePassword securepass=
			uint Type 0
			declare AccessList
			declare AdminOption
				uint deny_bridge 0
				uint deny_empty_password 0
				uint deny_qos 0
				uint deny_routing 0
				uint max_accesslists 0
				uint max_bitrates_download 0
				uint max_bitrates_upload 0
				uint max_groups 0
				uint max_sessions 0
				uint max_sessions_bridge 0
				uint max_sessions_client 0
				uint max_users 0
				uint no_cascade 0
				uint no_change_access_list 0
				uint no_change_cert_list 0
				uint no_change_crl_list 0
				uint no_change_groups 0
				uint no_change_log_config 0
				uint no_change_msg 0
				uint no_change_users 0
				uint no_delete_iptable 0
				uint no_delete_mactable 0
				uint no_disconnect_session 0
				uint no_enum_session 0
				uint no_offline 0
				uint no_online 0
				uint no_query_session 0
				uint no_read_log_file 0
				uint no_securenat 0
				uint no_securenat_enablenat 0
			declare CascadeList
			declare LogSetting
				uint PacketLogSwitchType 4
				uint PACKET_LOG_ARP 0
				uint PACKET_LOG_DHCP 1
				uint PACKET_LOG_ETHERNET 0
				uint PACKET_LOG_ICMP 0
				uint PACKET_LOG_IP 0
				uint PACKET_LOG_TCP 0
				uint PACKET_LOG_TCP_CONN 1
				uint PACKET_LOG_UDP 0
				bool SavePacketLog true
				bool SaveSecurityLog true
				uint SecurityLogSwitchType 4
			declare Message
			declare Option
				uint AdjustTcpMssValue 0
				bool DisableHttpParsing false
				bool DisableIPParsing false
				bool DisableIpRawModeSecureNAT false
				bool FilterBPDU false
				bool FilterIPv4 false
				bool FilterIPv6 false
				bool FilterNonIP false
				bool FilterOSPF false
				bool FilterPPPoE false
				bool ManageOnlyPrivateIP true
				uint MaxSession 0
				bool NoArpPolling false
				bool NoEnum false
				bool NoIpTable false
				bool NoIPv4PacketLog false
				bool NoIPv6AddrPolling false
				bool NoIPv6PacketLog false
				bool NoLookBPDUBridgeId false
				bool NoMacAddressLog true
				bool NoManageVlanId false
				uint RequiredClientId 0
				string VlanTypeId 0x8100
			declare SecureNAT
				bool Disabled true
				bool SaveLog true
				declare VirtualDhcpServer
					string DhcpDomainName $
					bool DhcpEnabled true
					uint DhcpExpireTimeSpan 7200
					string DhcpLeaseIPEnd 192.168.30.200
					string DhcpLeaseIPStart 192.168.30.10
					string DhcpPushRoutes $
				declare VirtualHost
					string VirtualHostMacAddress 5E-72-90-B2-C1-92
				declare VirtualRouter
					bool NatEnabled true
					uint NatMtu 1500
					uint NatTcpTimeout 1800
					uint NatUdpTimeout 60
				declare CertList
				declare CrlList
				declare GroupList
				declare IPAccessControlList
				declare UserList
					declare recodevpn
						byte AuthNtLmSecureHash hash==
						byte AuthPassword pass=
						uint AuthType 1
						uint64 CreatedTime 1536804880429
						uint64 ExpireTime 0
						string Note $
						uint NumLogin 4
						string RealName $
						uint64 UpdatedTime 1536804880429
						declare Traffic
							declare RecvTraffic
								uint64 UnicastBytes 46208
								uint64 UnicastCount 722
							declare SendTraffic
								uint64 BroadcastBytes 308180
								uint64 BroadcastCount 1616
								uint64 UnicastBytes 91234
								uint64 UnicastCount 1243
			declare Traffic
				declare RecvTraffic
				declare SendTraffic
server uses OpenSSL 1.1.0f 25 May 2017
Version history said "source now OpenSSL 1.1.0 compatible on 18th of August.
What am i missing? :(
Re: Debian Stretch
Post by thisjun » Thu Oct 04, 2018 6:56 am
What is your question?
cmd wh0ami
Re: Debian Stretch
Post by cmd wh0ami » Sat Oct 06, 2018 6:36 pm
For one, you did't declare local bridge... its not configured...
Which is fine if you use SecureNat... but that too is disabled....
			declare SecureNAT
				bool Disabled true
On top of that all your passwd and server certs are missing from the config... I don't know if you deleted them intentionally for this post, or if they are actually missing from your server config...
