Error Code 1 after about 24 hours uptime
Sysbgn
Post by Sysbgn » Sat Dec 08, 2018 9:51 am
Hi, I have a problem with Softheter VPN server installed on both computers running Windows Server 2008 and 2016. Both of them work like a charm, but after about 24 hours they both reject new connections. Active connections are not affected at that time. If I restart the computers then everything is ok the next 24 hours. Could you please give me a clue what I could be missing in settings?
P.S I use secure Nat settings and local bridge if that is important.
jongova
Re: Error Code 1 after about 24 hours uptime
Post by jongova » Fri Dec 14, 2018 7:58 am
I have the same problem. Ive made a firewall exception, tried to restart the service of SoftEther, installed the software on a Win 7 and Server 2016, but i still cant find a solution!
Post by thisjun » Thu Jan 24, 2019 6:03 am
Why do you use SecureNAT and localbridge at the same time?
Sysbgn
Post by Sysbgn » Sun Feb 10, 2019 11:17 pm
Sorry I wrote it wrong. I tried both secure nat and local bridge settings and both stopped working in about 24 hours. Restarting the server machine solve the problem for new 24 hours.
