BSOD - Crash Report - Can't boot anymore
Metathesus
Post by Metathesus » Sun Jan 13, 2019 7:06 pm
I don't know if it's the right place to report bugs on softether VPN...
My windows 2012 R2 wasn't able to boot work after installing Softether VPN.
BSOD occurs just after boot with error "Driver_IRQL_LESS_OR_EQUAL (MsLbfoProvider.sys)"
1) I have installed the server and make a bridge with a "team Network card"
I think the problem is there
I have used the last beta version
2) DHCP was Enable
3) I have installed the client on server and connected succesfully on locahost
4) I have installed the client on a distant machine => connect succefuly => Try to browse Network lead to a BSOD.
5) Windows wasn't stable and loop reboot with BSOD.
Hope you can reproduce and make correction.
Regards
Re: BSOD - Crash Report - Can't boot anymore
Post by thisjun » Thu Feb 21, 2019 4:48 am
Did you use SecureNAT and localbridge at same time?
If so, it makes a packet loop.
