Andriod does not connect.
TinkerMan
Post by TinkerMan » Mon Jan 21, 2019 12:08 pm
Hi all. I have installed version 4.24 build 9651 on a Raspberry Pi in 2017 and it works very well for iOS and Windows. But Andriod wont connect.
Was there an issue with that version ? Should I upgrade to resolve it ? If so is there an easy upgrade method ?
Kind Regards.
coreburner
Re: Andriod does not connect.
Post by coreburner » Wed Jan 23, 2019 7:16 pm
I had the same problem, I had to alter the ssl cipher order to get any android device to connect. this will fix the issue but I cant remember which android cipher i moved to the first position and i'm away from my server. SSLlabs has a list of ssl ciphers for each os, you can find the info you need there.
Post by thisjun » Thu Feb 21, 2019 6:48 am
Could you explain more about your configuration etc?
Android version, VPN protocol, App, network configuration, error message.
coreburner
Post by coreburner » Tue May 28, 2019 1:32 am
go to encryption settings, select AES256-GCM-SHA384 from the encryption algorithm drop down box. i use the built in android l2tp client works on android 7,8 and 9. make sure all of the l2tp ports are forwarded on your firewall.
