Log Message
badsmoke
Log Message
Post by badsmoke » Mon Feb 04, 2019 8:31 am
I have set up a Softether Server and a Softether Bridge.
The user should connect externally via the VPN directly to the DHCP/DNS server in the office.
This also works very well for the most part.
but I often have this message in my log:
A large volume of broadcast packets has been detected. There are cases where packets are discarded based on the policy. The source MAC address is 00-00-00-00-00-10, the source IP address is 0.0.0.0, the destination IP address is 0.0.0.0. The number of broadcast packets is equal to or larger than 36 items per 1 second (note this information is the result of mechanical analysis of part of the packets and could be incorrect).
Sometimes there are problems to connect to a Windows computer.
Re: Log Message
Post by thisjun » Thu Mar 28, 2019 6:26 am
Can you capture the packets in the virtual hub?
