Hi everybody!
recently my AV blocked some connections who tried to exploit some security vulnerability. I have attached the Log nearby.
I thought of posting this problem here because the target was the Server where the SE VPN runs and the PORT was Port Nummer on which SE VPN is Listening.
Is there a security Vulnerability in SE VPN Software? It says something about the "CVE-2017-5638: Apache Struts 2".
Any thought are welcome.
Kind regards,
claudelu
Security vulnerability exploitation
claudelu
Re: Security vulnerability exploitation
SoftEether VPN Server isn't affected by the vulnerability.
claudelu
Thank you for your answer.
