Hi All
Have a very basic set up allowing people to access network drives off site. I want to extend this to allow myself to access from an Android OS tablet. Following the instructions on the site I have to enable the IPsec/L2TP setting however as you can see from the photo this option is greyed out.
Is there something I'm completely missing here?
Thanks in advance, apologies for the rookie question
Cheers
Iain
Enable Ipsec/L2TP
Enable Ipsec/L2TP
Re: Enable Ipsec/L2TP
Did you connect to the VPN server with Virtual Hub Admin mode?
If so, please connect to the VPN server with Server Admin mode.
