RouterTableAdd command Network is not working
Tom168
Post by Tom168 » Wed Feb 13, 2019 5:15 pm
VPNServer Version : softether-vpnserver-v4.25-9656-rtm-2018.01.15-linux-x64-64bit
VPN Server> RouterTableAdd Guildford /NETWORK:10.10.201.120/24 /GATEWAY:10.10.201.1 /METRIC:1
Specify in the format of "IPv4 address/subnet mask".
Specify the IPv4 address by separating the decimal values using dots such as "192.168.0.1". For the subnet mask, either specify decimal values separated by dots such as "255.255.255.0", or you can specify the bit length of subnet mask using a decimal value such as 24.
To specify a standalone host, specify the subnet mask as either "255.255.255.255" or "32".
(Example)
192.168.0.1/24
192.168.0.1/255.255.255.0
192.168.0.5/255.255.255.255
Network Address/Subnet Mask: 10.10.201.120/24
The specified IP address is not a network address.
Network Address/Subnet Mask: 10.10.201.120/24 is not working, /NETWORK:10.10.201.120/24 is not working, but it is working in RouterIfAdd.
How to type the NETWORK for command RouterTableAdd?
Thanks.
Tom
Re: RouterTableAdd command Network is not working
Post by thisjun » Thu Apr 25, 2019 1:34 am
Network address should be 0 after netmask.
RouterTableAdd Guildford /NETWORK:10.10.201.0/24 /GATEWAY:10.10.201.1 /METRIC:1
