do i need to open these ports?
kush
Post by kush » Wed Feb 20, 2019 11:14 pm
hello i have hosted a Softether VPN server, do i need to open 992 and 5555 TCP ports in my router? and if yes what are those ports used for? and if not can i delete them from my listeners list?
and also the VPN server Software isn't listening the IPsec/L2TP ports but i opened ports 500 and 4500 in my router and connected to the server using L2TP setting so idk should i add them listener?
Re: do i need to open these ports?
Post by thisjun » Thu Apr 25, 2019 2:13 am
If you do not use TCP 992 and 5555 for VPN connection, you do not need to open these ports.
What is 'idk'?
fenice
Post by fenice » Thu Apr 25, 2019 4:33 am
What is 'idk'?
It's shorthand for 'I don't know'. :)
Regards
Bill
jaiz01
Post by jaiz01 » Fri Apr 26, 2019 1:24 pm
if you are using tcp connection then you need to open those ports otherwise no need
