"Connect to VPN" script for Linux
ceremcem
Post by ceremcem » Sat Feb 23, 2019 5:25 pm
I've experienced some sort of trouble while connecting to SoftEther server with my Linux machine, so I prepared the following script:
https://github.com/ceremcem/softether-h ... ect-vpn.sh
It's not perfect, but does the job in one script.
Re: "Connect to VPN" script for Linux
Post by thisjun » Tue May 21, 2019 4:58 am
What problem do you have?
ceremcem
Post by ceremcem » Fri May 31, 2019 6:43 pm
Currently nothing important. Above script performs all necessary settings. I just wanted to share it with everyone.
boink
Post by boink » Sat Jun 01, 2019 4:00 pm
It has been a bit of a pain to set up the Linux sstp-client.
For most, the most difficult part if setting up the routing once the connection has been made. Most VPN clients do this for you automagically.
Thus, when you do it yourself -- it is a positive learning experience.
I had a good look at the documentation and the how-to, it was very well written.
Thanks for taking the time to write good documentation.
