Multi Softether VPN Server
nelson77
Post by nelson77 » Sun Mar 31, 2019 11:00 am
Hi All, I have a question and not sure it's possible to do that with softether or not.
I have 2 VPS server both of them are installed Softether Server (VPS A and VPS B). I have no problem connect to VPS B from my local machine and the speed is fast, but for VPS A it's high latency and slow from my local.
I have tested from VPS B to VPS A it's fast also without the high latency issues. I have a idea, I installed the softether client in VPS B to connecting VPS A and then I use softether client to connect my VPS B to take the VPS A connecting... but once I try to connect to VPS B the connecting was failed its because the VPS B already connecting to VPS A's IP.
Hope any master can tell me it's possible to do that or not, or have other way. Many Thanks!
Re: Multi Softether VPN Server
Post by thisjun » Tue Jun 04, 2019 6:27 am
How about creating a cascade connection from VPS B to VPS A then connecting to VPS B from the client?
