Hello !
I want to use virtual DHCP function (without secure nat) to automatic assig ip address to vpn clients.
They should see only vpn Server without his local network.
I made virtual subnet with virtual dhcp and do not set defaul gateaway - because i don't need vpn clients internet traffic move through Server.
Also i setuped local bridge.
This settings works perfect for me.
-Clients connect to vpn server
-Server gives them ip in virtual subnet
-Clients can connect to server with rdp-connection by his name
But i have a big problem - computers and tablets from Server's local network ALSO connect to Softether Virtual DHCP.
I can't setup static ip's to all devices.
HOW CAN I MAKE Softether Virtual DHCP ONLY FOR VPN CLIENTS ?
p.s. i can't turn off local bridge- rdp connection to server don't work without it
VIRTUAL DHCP ONLY FOR VPN CLIENTS
Re: VIRTUAL DHCP ONLY FOR VPN CLIENTS
Please disable the localbridge and install SoftEther VPN Client on the VPN server.
Then, connect the client to the SoftEther VPN Server.
