IP Address Does Not Change
jobo
Post by jobo » Wed Apr 24, 2019 6:51 pm
I am not exactly technically inclined when it comes to vpns and networks so if there is another thread where this problem has already been solved, please direct me there.
My problem has come up relatively recently where I will connect to a server and it will say that I am connected both to my local connection and the vpn server at the same time and my IP remains unchanged. I've looked at a few different possible solutions and none of them have worked yet. I tried installing the latest version of the vpn software and nothing has changed. I don't know what exactly I'm doing wrong. I don't know how to check if, maybe, the recent Windows update my pc ran is blocking it somehow? I'm running a windows 10 machine and for the 2 1/2 years I've had this vpn software it's worked perfectly fine up until very recently.
Does anyone know how to fix this? I'm not even sure if I was specific enough since I don't know how precisely to explain what is happening. I appreciate any help.
Re: IP Address Does Not Change
Post by thisjun » Wed Jun 05, 2019 4:24 am
Could you explain about your VPN server configuration and network environment?
