Receiving Error 131
wxw663
Receiving Error 131
Post by wxw663 » Sun May 05, 2019 1:31 pm
I am in trouble with logining in my vpn server using server manager on Windows.
Many times it shows error 131 that several vpn servers are on the same IP address, but i only set up one server.
I cannot also use the client manager to connect to the server because of the same error, but i can use the built-in vpn to connect to the server.
I also found that when i successfully connect to the server (not only the one above), the network center shows i have no internet connection, but i can use the internet and the public ip is the ip of vpn server. Can this be properly showed?
Thank you.
Re: Receiving Error 131
Post by thisjun » Wed Jun 05, 2019 6:09 am
Could you explain the VPN server configuration and network environment etc?
