SoftEther VPN client connection to OpenVPN server
lmw
Post by lmw » Sun May 05, 2019 5:10 pm
Hi all,
Is it possible to setup SoftEther VPN client to connect to an OpenVPN server which is listening on UDP 1194?
I cannot find the way to configure an UDP port when defining a new VPN connection on the client.
My client setup: Windows 10
Thanks in advance :)
lmw
Re: SoftEther VPN client connection to OpenVPN server
Post by lmw » Sat May 11, 2019 8:35 am
Hi all,
I am very surprised to have no answer at all.
Does anyone know if this is possible please?
Thanks in advance for your time and for your help.
sky59
Post by sky59 » Sat May 11, 2019 8:25 pm
Do not be surprised. I already passed all that you experience now. Read my posts.
Do not use OpenVPN it is useless, it is blocked by every router.
I use exlusively only softether with https port 443. No router can block this. Already tested 100000x times.
Where openvpn is blocked the softether still works!
lmw
Post by lmw » Mon May 13, 2019 8:20 am
Hi sky59,
Well, sure, we will move to SoftEther server too as soon as we can, but waiting for that to be done, we have still an OpenVPN server running.
So is it possible to setup a SoftEther VPN client to connect to an OpenVPN server?
That is my only question. ;)
Thanks and in advance for your help.
centeredki69
Post by centeredki69 » Mon May 13, 2019 10:08 pm
Hello LMW,
NO
The softether "Client" cannot be used to connect to an OpenVPN server. It is designed to connect a Softether "server" running the ethernet over SSL (HTTPS) protocol.
For OpenVPN you will need to use an OpenVPN client.
However, a Softether "Server" can function as a Softehter SSL-VPN (HTTPS) and 6 other major VPN protocols (OpenVPN, IPsec, L2TP, MS-SSTP, L2TPv3 and EtherIP)
lmw
Post by lmw » Tue May 14, 2019 8:20 am
Ok, that is clear now.
Thank your for your answer.
