Hello everyone,
i need to migrate SoftEther to another server. I have some user which are configured to autenticate with "certificate" and other with "user and password". I was wondering if there is a way to export configuration from server1 and import configuration on server2?
Any suggestion or work around would be appreciate.
Thanks in advance,
Luca.
SoftEther VPN Server migration from one server to another
Re: SoftEther VPN Server migration from one server to anothe
Hmmm I don't know of any automatic way of doing a migration, you will just have to install SoftEther on the new machine, then copy the following files/directories:
vpn_server.config
chain_certs/
vpn_server.config
chain_certs/
I will give it a try as soon as i can, because the two server are in production
Then please experiment first in some lab environment before applying that to live servers
If you want to move DDNS name, you have to overwrite DDNS key in configuration after running destination VPN server.
I tried this when I was migrating my VPN server to another separate host server to reduce on the load on the first host server. It worked perfectly well.moatazelmasry wrote: ↑Mon Oct 17, 2016 4:07 pmHmmm I don't know of any automatic way of doing a migration, you will just have to install SoftEther on the new machine, then copy the following files/directories:
vpn_server.config
chain_certs/
Thanks a lot
Re: SoftEther VPN Server migration from one server to another
hi, this is not an answer since others hv posted them earlier. this is more a sharing and hopefully someone could shed some light for me ;p
i hv tried migrating the server recently, i backup and restore hamcore.se2 as well. Most of the things works, but not everything. for eg. i hvto manually edit and change the Ddns in the config so the new server would change and use the old Ddns. But one thing i couldn't make it work is SSL certificates. So OpenVPN, SE and L2TP works just like before, but MS-SSTP wouldn't work....
the best i could do is backup and restore the cert using Server Manager(since there are nothing in the chain_certs folder), but it will say CN name is different and fail....
anyone could help?
cheers,
anyone could help?
cheers,
