Local lan not accessing intert or lan
sa1213
Post by sa1213 » Mon May 06, 2019 1:06 pm
I need to use my router as the DHCP server for local lan clients. As of now, softether is handing down ip address to the local lan clients and they cannot access the internet or local lan resources. I only have three clients that use the softether vpn. is it possible to also have my router hand down ip addresses to the softether clients also?
SOftEther is using Secure NAT with the virtual DHCP server on. It is set to the default network settings.
Softether works great. Clients connect quick and is very stable. However, Softether is not allowing local or internet traffic on local lan dhcp clients.
If I turn off the virtual DHCP server in Secure NAT on Softether, will my router take over and hand the softether clients ip addresses?
Local lan is 192.168.0/24
SoftEther Secuer NAT default settings 192.168.30.10-200. SUb 255.255.255.0
Thanks,
Steve
Re: Local lan not accessing intert or lan
Post by thisjun » Wed Jun 05, 2019 6:19 am
Please use localbridge instead of the SecureNAT.
