Why can't I create a HUB named VPNGATE
jidawei
Post by jidawei » Sun May 12, 2019 5:55 am
Most of the nodes in China are not available. Now I have a host in Hong Kong that can be used by any host in Hong Kong
Can I use the host computer in Hong Kong as the relay between my computer and SOFT?What should I do if I can?
sky59
Re: Why can't I create a HUB named VPNGATE
Post by sky59 » Sun May 12, 2019 6:33 am
Why can't I create a HUB named VPNGATE ---- where?
Most of the nodes in China are not available. ---- what is node?
Now I have a host in Hong Kong that can be used by any host in Hong Kong ---- what is host? server? what server?
Can I use the host computer in Hong Kong as the relay between my computer and SOFT?What should I do if I can? --- what is soft?
jidawei
Post by jidawei » Sun May 12, 2019 8:52 am
Why can't I create a HUB named VPNGATE ---- where? ----This is when the virtual HUB name is created in the LINUX system
Most of the nodes in China are not available. ---- what is node?----The VPN line
Now I have a host in Hong Kong that can be used by any host in Hong Kong ---- what is host? server? what server?-----Hong Kong VPS
Can I use the host computer in Hong Kong as the relay between my computer and SOFT?What should I do if I can? --- what is soft?---HKVPS
sky59
Post by sky59 » Sun May 12, 2019 9:35 am
What is linux system??? Linux has nothing to do with vpn. What vpn server/bridge/client you use?
Line has nothing to do with vpn. What is the server for vpn?
You mean VPN server? What sort of server is running in HK? OpenVpn? FreeVPN? SoftEther? something else?
This is chaos you must make a picture
jidawei
Post by jidawei » Sun May 12, 2019 10:04 am
I am using Google to translate the expression is not clear
可惜论坛上不知道有没有中国的大佬
centeredki69
Post by centeredki69 » Mon May 13, 2019 10:30 pm
Hello jidawei,
Are you saying you have installed the Softether "Server" software on a Linux server and you want to create a virtual HUB named VPNGATE?
Are you using the SoftEther "Server Manager" to Manage your Softether Server?
jidawei
Post by jidawei » Wed May 15, 2019 4:07 am
yes
joegunn
Post by joegunn » Thu May 16, 2019 3:11 am
I also want to know how to create a HUB
Don't wait.
spanish dictionary traductor, geometry dash full
fenice
Post by fenice » Thu May 16, 2019 9:59 am
Have you read the documentation or any of the many tutorials on the internet? You should do that first and then ask questions if you have problems.
Regards
Bill
