I'm wondering, is it even possible to connect to the L2TP/IPSec server with certificate using the built-in Windows client?
It says me "Error 798: cannot find the EAP certificate", despite the fact that I imported the certificate into the Windows certificate store and selected this certificate in the properties of the VPN adapter.
L2TP/IPSec using certificate with built-in Windows client
0xDEAD
Re: L2TP/IPSec using certificate with built-in Windows client
SoftEther VPN Server doesn't support cert auth with L2TP/IPSec.
nologo73
Hi everyone,
I am writing just to know if, with new beta version is possible to use certificate with L2TP over Ipsec
or still SoftEther VPN Server doesn't support cert auth with L2TP/IPSec
thank you
nolo
thank you
nolo
