i had set up softether vpn server on Linux Ubuntu,everything worked for a long time until the moment when there was no electricity.
When I restarted the server with VPN virtualization, it stopped working.
The service is running but it does not work, any ideas?
Softether VPN - Doesnt work
boink
Re: Softether VPN - Doesnt work
I would do a reinstall. It could be that some data got corrupted on your hard disk due to the crash.
Meqookapi
I think there are some troubles with your PC. Maybe you should check your hard drive.
