where is the softether VPN client for Andriod & IOS?
cyf2004
Post by cyf2004 » Mon Jun 10, 2019 2:03 am
Hi All,
Could anyone tell me where is the softether VPN client for Andriod & IOS? I found a long time for it,but I have no idea to find it. Thanks.
sky59
Re: where is the softether VPN client for Andriod & IOS?
Post by sky59 » Mon Jun 10, 2019 7:06 am
for ios you must compile existing source code, i tried and it works without any need for "adjustment", it compiles without error
for android it does not officially exist: but i found source, someone made adjustment like using different tmp folder and so on.. android is different
Then it needed A LOT of adjustments, installations but it finally works, i made it for API14
But it is buggy when i start client i must manually correct ip route table, it makes chaos, it is source code problem because client behaves in exactly stupid way also on ubuntu linux computer /no adjustments were needed to compile it/
Also android must be rooted otherwise you can not start client, i start it from terminal window
Search my posts here i made a lot of photos
https://www.vpnusers.com/viewtopic.php? ... 339#p86339
https://www.vpnusers.com/viewtopic.php? ... 249#p86249
coolname
Post by coolname » Mon Jun 10, 2019 8:13 am
Hi Sky59, could you please elaborate on how to compile the existing source code for Apple iOS client? I've heard that s/e only offers SSL client for Windows, Mac, and Linux but there is not such SSL client for android and iOS.
sky59
Post by sky59 » Mon Jun 10, 2019 8:42 am
Ios is mac, is not it?
I compiled it on colleague's air ibook /i do not remember that stupid apples names/
Just unpack and run make, if i remember correct, but i do know nothing special was needed
Dwebtron
Post by Dwebtron » Mon Jun 10, 2019 11:38 pm
iOS is iPhone, OSX is Mac/Macbooks.
Android, while based on Linux, doesn't always behave the same.
jayko
Post by jayko » Fri Jul 19, 2019 7:30 am
Hi Sky59, you manage to get the softether client to compile from the source in macOS? is that what you implied?
I downloaded the source code, and it require the following:
ou need to install the following software to build SoftEther VPN for UNIX.
- Linux, FreeBSD, Solaris or Mac OS X.
- GNU Compiler Collectipon (gcc) and binary utilities.
- GNU Make (gmake).
- GNU C Library (glibc).
- POSIX Threads (pthread).
- OpenSSL (crypto, ssl).
- libiconv.
- readline.
- ncurses.
for macOS to be able to compile the source code. you manage to get all those list aboved?
thanks
sky59
Post by sky59 » Fri Jul 19, 2019 2:21 pm
yes, my colleage has got company development iMac and he has everything for development on it
jayko
Post by jayko » Sat Jul 20, 2019 2:16 am
ok, cool, I install xcode 8 and compile the source code, and got into :
'openssl/ssl.h' file not found
already try to google for solution but doesn't seems to work.
do you mind to share what is the xcode version they are using?
jayko
Post by jayko » Sat Jul 20, 2019 3:36 pm
Hi Sky59,
I manage to proceed with the compilation but stuck at linker part, do you know if anything missing here?
Thanks.
Jays-Mac-mini:SoftEtherVPN_Stable jayko$ make
cc -DNDEBUG -DVPN_SPEED -DUNIX -DUNIX_MACOS -DBRIDGE_PCAP -DCPU_64 -D_REENTRANT -DREENTRANT -D_THREAD_SAFE -D_THREADSAFE -DTHREAD_SAFE -DTHREADSAFE -D_FILE_OFFSET_BITS=64 -I./src/ -I./src/Cedar/ -I./src/Mayaqua/ -O2 -fsigned-char -m64 tmp/objs/Mayaqua/Cfg.o tmp/objs/Mayaqua/Encrypt.o tmp/objs/Mayaqua/FileIO.o tmp/objs/Mayaqua/Internat.o tmp/objs/Mayaqua/Kernel.o tmp/objs/Mayaqua/Mayaqua.o tmp/objs/Mayaqua/Memory.o tmp/objs/Mayaqua/Microsoft.o tmp/objs/Mayaqua/Network.o tmp/objs/Mayaqua/Object.o tmp/objs/Mayaqua/OS.o tmp/objs/Mayaqua/Pack.o tmp/objs/Mayaqua/Secure.o tmp/objs/Mayaqua/Str.o tmp/objs/Mayaqua/Table.o tmp/objs/Mayaqua/TcpIp.o tmp/objs/Mayaqua/Tick64.o tmp/objs/Mayaqua/Tracking.o tmp/objs/Mayaqua/Unix.o tmp/objs/Mayaqua/Win32.o tmp/objs/Cedar/Account.o tmp/objs/Cedar/Admin.o tmp/objs/Cedar/AzureClient.o tmp/objs/Cedar/AzureServer.o tmp/objs/Cedar/Bridge.o tmp/objs/Cedar/BridgeUnix.o tmp/objs/Cedar/BridgeWin32.o tmp/objs/Cedar/Cedar.o tmp/objs/Cedar/CedarPch.o tmp/objs/Cedar/Client.o tmp/objs/Cedar/CM.o tmp/objs/Cedar/Command.o tmp/objs/Cedar/Connection.o tmp/objs/Cedar/Console.o tmp/objs/Cedar/Database.o tmp/objs/Cedar/DDNS.o tmp/objs/Cedar/EM.o tmp/objs/Cedar/EtherLog.o tmp/objs/Cedar/Hub.o tmp/objs/Cedar/Interop_OpenVPN.o tmp/objs/Cedar/Interop_SSTP.o tmp/objs/Cedar/IPsec.o tmp/objs/Cedar/IPsec_EtherIP.o tmp/objs/Cedar/IPsec_IKE.o tmp/objs/Cedar/IPsec_IkePacket.o tmp/objs/Cedar/IPsec_IPC.o tmp/objs/Cedar/IPsec_L2TP.o tmp/objs/Cedar/IPsec_PPP.o tmp/objs/Cedar/IPsec_Win7.o tmp/objs/Cedar/Layer3.o tmp/objs/Cedar/Link.o tmp/objs/Cedar/Listener.o tmp/objs/Cedar/Logging.o tmp/objs/Cedar/Nat.o tmp/objs/Cedar/NativeStack.o tmp/objs/Cedar/NM.o tmp/objs/Cedar/NullLan.o tmp/objs/Cedar/Protocol.o tmp/objs/Cedar/Radius.o tmp/objs/Cedar/Remote.o tmp/objs/Cedar/Sam.o tmp/objs/Cedar/SecureInfo.o tmp/objs/Cedar/SecureNAT.o tmp/objs/Cedar/SeLowUser.o tmp/objs/Cedar/Server.o tmp/objs/Cedar/Session.o tmp/objs/Cedar/SM.o tmp/objs/Cedar/SW.o tmp/objs/Cedar/UdpAccel.o tmp/objs/Cedar/UT.o tmp/objs/Cedar/VG.o tmp/objs/Cedar/Virtual.o tmp/objs/Cedar/VLan.o tmp/objs/Cedar/VLanUnix.o tmp/objs/Cedar/VLanWin32.o tmp/objs/Cedar/WaterMark.o tmp/objs/Cedar/WebUI.o tmp/objs/Cedar/WinUi.o tmp/objs/Cedar/Wpc.o src/hamcorebuilder/hamcorebuilder.c -O2 -fsigned-char -m64 -lm -lpthread -lssl -lcrypto -liconv -lreadline -lncurses -lz -lpcap -o tmp/hamcorebuilder
tmp/hamcorebuilder src/bin/hamcore/ src/bin/BuiltHamcoreFiles/unix/hamcore.se2
hamcore.se2 Build Utility
Src Dir: 'src/bin/hamcore/'
Dest Filename: 'src/bin/BuiltHamcoreFiles/unix/hamcore.se2'
Processing...
src/bin/hamcore/authors.txt: 82 -> 78
src/bin/hamcore/backup_dir_readme.txt: 314 -> 130
src/bin/hamcore/empty.config: 37 -> 42
src/bin/hamcore/empty_sevpnclient.config: 1921 -> 866
src/bin/hamcore/eula.txt: 3587 -> 1671
src/bin/hamcore/install_src.dat: 13 -> 21
src/bin/hamcore/lang.config: 698 -> 409
src/bin/hamcore/languages.txt: 403 -> 346
src/bin/hamcore/languages_wine.txt: 260 -> 223
src/bin/hamcore/legal.txt: 43321 -> 12071
src/bin/hamcore/openvpn_readme.pdf: 490556 -> 479129
src/bin/hamcore/openvpn_readme.txt: 13030 -> 5081
src/bin/hamcore/openvpn_sample.ovpn: 4535 -> 1682
src/bin/hamcore/root_certs.dat: 400489 -> 275260
src/bin/hamcore/SOURCES_OF_BINARY_FILES.TXT: 6167 -> 2530
src/bin/hamcore/strtable_cn.stb: 564093 -> 151976
src/bin/hamcore/strtable_en.stb: 646635 -> 147560
src/bin/hamcore/strtable_ja.stb: 811031 -> 157501
src/bin/hamcore/vpnserver_api_doc.html: 627154 -> 53763
src/bin/hamcore/vpnweb_sample_cn.htm: 3965 -> 1578
src/bin/hamcore/vpnweb_sample_en.htm: 3965 -> 1578
src/bin/hamcore/vpnweb_sample_ja.htm: 4856 -> 1978
src/bin/hamcore/warning_cn.txt: 32104 -> 11779
src/bin/hamcore/warning_en.txt: 37596 -> 11815
src/bin/hamcore/warning_ja.txt: 52545 -> 13598
src/bin/hamcore/webui/cryptcom.cgi: 1729 -> 865
src/bin/hamcore/webui/edituser.cgi: 1495 -> 723
src/bin/hamcore/webui/error.cgi: 279 -> 243
src/bin/hamcore/webui/hub.cgi: 2633 -> 893
src/bin/hamcore/webui/license.cgi: 1852 -> 895
src/bin/hamcore/webui/listener.cgi: 463 -> 328
src/bin/hamcore/webui/localbridge.cgi: 1876 -> 918
src/bin/hamcore/webui/login.cgi: 767 -> 499
src/bin/hamcore/webui/newhub.cgi: 805 -> 473
src/bin/hamcore/webui/redirect.cgi: 254 -> 177
src/bin/hamcore/webui/securenat.cgi: 3169 -> 1125
src/bin/hamcore/webui/server.cgi: 2367 -> 960
src/bin/hamcore/webui/session.cgi: 979 -> 546
src/bin/hamcore/webui/user.cgi: 951 -> 533
src/bin/hamcore/webui/webui.css: 30 -> 38
src/bin/hamcore/wwwroot/index.html: 1999 -> 908
src/bin/hamcore/wwwroot/admin/index.html: 274 -> 180
src/bin/hamcore/wwwroot/admin/README.md: 1170 -> 557
src/bin/hamcore/wwwroot/admin/default/.gitignore: 15 -> 23
src/bin/hamcore/wwwroot/admin/default/hub.html: 653 -> 339
src/bin/hamcore/wwwroot/admin/default/include_footer.html: 106 -> 92
src/bin/hamcore/wwwroot/admin/default/include_head.html: 692 -> 296
src/bin/hamcore/wwwroot/admin/default/include_menu.html: 1464 -> 490
src/bin/hamcore/wwwroot/admin/default/index.html: 2878 -> 1192
src/bin/hamcore/wwwroot/admin/default/package-lock.json: 170740 -> 37920
src/bin/hamcore/wwwroot/admin/default/package.json: 608 -> 299
src/bin/hamcore/wwwroot/admin/default/theme.css: 273 -> 166
src/bin/hamcore/wwwroot/admin/default/tsconfig.json: 5449 -> 1839
src/bin/hamcore/wwwroot/admin/default/tsconfig_webpack.json: 5440 -> 1840
src/bin/hamcore/wwwroot/admin/default/tslint.json: 523 -> 225
src/bin/hamcore/wwwroot/admin/default/webpack.config.js: 833 -> 377
src/bin/hamcore/wwwroot/admin/default/.vscode/launch.json: 454 -> 226
src/bin/hamcore/wwwroot/admin/default/.vscode/settings.json: 82 -> 74
src/bin/hamcore/wwwroot/admin/default/.vscode/tasks.json: 1198 -> 328
src/bin/hamcore/wwwroot/admin/default/out_webpack/bundle.js: 2622100 -> 614017
src/bin/hamcore/wwwroot/admin/default/out_webpack/ts/index.d.ts: 542 -> 256
src/bin/hamcore/wwwroot/admin/default/out_webpack/ts/index.d.ts.map: 555 -> 242
src/bin/hamcore/wwwroot/admin/default/out_webpack/ts/main.d.ts: 620 -> 264
src/bin/hamcore/wwwroot/admin/default/out_webpack/ts/main.d.ts.map: 624 -> 256
src/bin/hamcore/wwwroot/admin/default/out_webpack/ts/vpnadmin.d.ts: 50 -> 58
src/bin/hamcore/wwwroot/admin/default/out_webpack/ts/vpnadmin.d.ts.map: 116 -> 98
src/bin/hamcore/wwwroot/admin/default/src/ts/main.ts: 5662 -> 1736
authors.txt: offset: 2773
backup_dir_readme.txt: offset: 2851
empty.config: offset: 2981
empty_sevpnclient.config: offset: 3023
eula.txt: offset: 3889
install_src.dat: offset: 5560
lang.config: offset: 5581
languages.txt: offset: 5990
languages_wine.txt: offset: 6336
legal.txt: offset: 6559
openvpn_readme.pdf: offset: 18630
openvpn_readme.txt: offset: 497759
openvpn_sample.ovpn: offset: 502840
root_certs.dat: offset: 504522
SOURCES_OF_BINARY_FILES.TXT: offset: 779782
strtable_cn.stb: offset: 782312
strtable_en.stb: offset: 934288
strtable_ja.stb: offset: 1081848
vpnserver_api_doc.html: offset: 1239349
vpnweb_sample_cn.htm: offset: 1293112
vpnweb_sample_en.htm: offset: 1294690
vpnweb_sample_ja.htm: offset: 1296268
warning_cn.txt: offset: 1298246
warning_en.txt: offset: 1310025
warning_ja.txt: offset: 1321840
webui\cryptcom.cgi: offset: 1335438
webui\edituser.cgi: offset: 1336303
webui\error.cgi: offset: 1337026
webui\hub.cgi: offset: 1337269
webui\license.cgi: offset: 1338162
webui\listener.cgi: offset: 1339057
webui\localbridge.cgi: offset: 1339385
webui\login.cgi: offset: 1340303
webui\newhub.cgi: offset: 1340802
webui\redirect.cgi: offset: 1341275
webui\securenat.cgi: offset: 1341452
webui\server.cgi: offset: 1342577
webui\session.cgi: offset: 1343537
webui\user.cgi: offset: 1344083
webui\webui.css: offset: 1344616
wwwroot\admin\default.gitignore: offset: 1344654
wwwroot\admin\default.vscode\launch.json: offset: 1344677
wwwroot\admin\default.vscode\settings.json: offset: 1344903
wwwroot\admin\default.vscode\tasks.json: offset: 1344977
wwwroot\admin\default\hub.html: offset: 1345305
wwwroot\admin\default\include_footer.html: offset: 1345644
wwwroot\admin\default\include_head.html: offset: 1345736
wwwroot\admin\default\include_menu.html: offset: 1346032
wwwroot\admin\default\index.html: offset: 1346522
wwwroot\admin\default\out_webpack\bundle.js: offset: 1347714
wwwroot\admin\default\out_webpack\ts\index.d.ts: offset: 1961731
wwwroot\admin\default\out_webpack\ts\index.d.ts.map: offset: 1961987
wwwroot\admin\default\out_webpack\ts\main.d.ts: offset: 1962229
wwwroot\admin\default\out_webpack\ts\main.d.ts.map: offset: 1962493
wwwroot\admin\default\out_webpack\ts\vpnadmin.d.ts: offset: 1962749
wwwroot\admin\default\out_webpack\ts\vpnadmin.d.ts.map: offset: 1962807
wwwroot\admin\default\package-lock.json: offset: 1962905
wwwroot\admin\default\package.json: offset: 2000825
wwwroot\admin\default\src\ts\main.ts: offset: 2001124
wwwroot\admin\default\theme.css: offset: 2002860
wwwroot\admin\default\tsconfig.json: offset: 2003026
wwwroot\admin\default\tsconfig_webpack.json: offset: 2004865
wwwroot\admin\default\tslint.json: offset: 2006705
wwwroot\admin\default\webpack.config.js: offset: 2006930
wwwroot\admin\index.html: offset: 2007307
wwwroot\admin\README.md: offset: 2007487
wwwroot\index.html: offset: 2008044
Writing src/bin/BuiltHamcoreFiles/unix/hamcore.se2...
Done.
cp src/bin/BuiltHamcoreFiles/unix/hamcore.se2 bin/vpnserver/hamcore.se2
cc tmp/as/vpnserver.a -O2 -fsigned-char -m64 -lm -lpthread -lssl -lcrypto -liconv -lreadline -lncurses -lz -lpcap -o bin/vpnserver/vpnserver
ld: archive has no table of contents file 'tmp/as/vpnserver.a' for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make: *** [bin/vpnserver/vpnserver] Error 1
