enterprises functions are currently disabled by default in Region of china
xiayu
Post by xiayu » Wed Jun 19, 2019 10:58 am
I found a source code:
is_restricted = SiIsEnterpriseFunctionsRestrictedOnOpenSource(s->Cedar);
SetGlobalServerFlag(GSF_DISABLE_PUSH_ROUTE, is_restricted);
SetGlobalServerFlag(GSF_DISABLE_RADIUS_AUTH, is_restricted);
SetGlobalServerFlag(GSF_DISABLE_CERT_AUTH, is_restricted);
SetGlobalServerFlag(GSF_DISABLE_DEEP_LOGGING, is_restricted);
SetGlobalServerFlag(GSF_DISABLE_AC, is_restricted);
SetGlobalServerFlag(GSF_DISABLE_SYSLOG, is_restricted);
So How to Remove Disabled Function?Thank you all.
xiayu
Re: enterprises functions are currently disabled by default in Region of china
Post by xiayu » Thu Jun 20, 2019 5:14 am
私はもう解決しました。話題を閉じます。
xiayu
搞定,关闭该问题!
lwk523
Post by lwk523 » Sun Aug 11, 2019 5:01 am
xiayu wrote: ↑
Hi xiayu, can i have your qq/wechat as sharing for using softether in china
Thanks
