Is the Azure VPN Gateway ANY kind of requirement for SoftEther to function?
I do not believe it is, but wanted to run it past the community before I start to delete things.
Thank you,
Azure setup - VPN Gateway
Re: Azure setup - VPN Gateway
Do you have any problem with VPN Azure?
