VPNBridge How To
odianosen
VPNBridge How To
Post by odianosen » Sat Jun 22, 2019 6:39 am
Please thanks for this great project first.
I want to use the JSONRPC api to control a vpnbridge, so I could instruct it when to connect, and disconnect from a remote server. Am I wrong if I say the supported jsonrpc api, is only for the Server and not Bridge? I know its definitely not for client.
Also the computer that is running the bridge, it seems one cannot access it over the VPN, even though other computers can be accessed? For example, if I want to still ssh to it, even if its the bridge. Am I right to say this is not possible? And if it is, can I be directed on how to set it up please?
Kind regards
Re: VPNBridge How To
Post by thisjun » Tue Jul 09, 2019 5:01 am
SofteEther VPN supports JSON-RPC in the latest version.
riny
Post by riny » Fri Jul 12, 2019 3:16 pm
That's correct. Here's my solution to that problem: https://www.vpnusers.com/viewtopic.php?f=7&t=64358
odianosen
Post by odianosen » Sat Jul 27, 2019 7:47 pm
Thanks for the response everyone. I am sorry I am just responding, as I didn't get any email alert or something telling me I had a response. Very much appreciated.
Thanks for this and yes I am aware now, but can you help me with some python code examples? As I am not sure how to implement it.
Thanks for this, but the solution doesn't allow for L2 access which i important to me. I will go with the first solution and use a USb to Ethernet adaptor.
Regards
